Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Error after closing Revit 2009
    2004-06
    Memphis TN area
    7,048
    Default Error after closing Revit 2009
    Lately I've been getting an Application Error message a few seconds after closing out of Revit 2009. It has the red "X" symbol (typical Windows error message) and reads:
    The instruction at "0x0114ef7a" referenced memory at "0x00000020". The memory could not be "read".
    Click on OK to terminate the program.
    Looks like what happens when you do something that causes the machine to run out of memory. However this is AFTER I've already closed the program.
    Any ideas? I'm on a quad-core machine with 4 GB RAM.
    2003-05
    North Texas
    105
    Default Re: Error after closing Revit 2009
    Please file a support request on this. I've been seeing this since the beta, but support is telling me they aren't seeing it.
    2006-01
    4,516
    I see it here too. Every single day, when i close Revit at the end of the day.
    Dual core Xeon, 4 gigs ram (3.25 visible on winXP32) and 3gig switch enabled.
    Runs fine, but gives me a memory error shutting down Revit.
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    I get this one too.
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    I don't get it when Rvt simply crashes.
    2007-06
    Melbourne, Australia
    602
    I get the same error, but only occasionally!!???
    Pentium 4
    4 gig ram
    I don't think I have lost any data as a result, but it is worrying neverthelsss
    Cheers,
    Ian
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    I used to get this error daily, but now not so much -- which I don't understand
    2006-05
    London, England
    37
    I get the same error maybe 3 times a week.
    Phil
    London
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    We were getting this after first upgrading to R2009, but I don't think it's happened in a while. We surmised it had something to do with upgrading projects/families.
    Fortunately, it just seems to be more quirky 2009 behavior and doesn't appear to affect the actual use of Revit.
    (yes, we did file a support request, but they didn't seem to know what to make of it and after about a week, it was closed).
    All AUGI, all the time Henry D's Avatar
    2003-05
    Fairfield, Iowa
    669
    Take a look at the Processes under the Windows Task Manager. What I find sometimes is that when I close Revit even though Revit disappears off the screen, the Processes still show Revit is running with a lot of memory usage. Slowly the memory usage will go down and Revit.exe will eventually disappear from the processes list. Then if needed Revit can be started again. I also have a dual quad with 5 GB RAM.
    This doesn't really solve the issue other than making me be more patient!
    Quote Originally Posted by patricks View Post
  1. 2008: Publish error: Error closing document
    By LanceMcHatton in forum AutoCAD Plotting
    Last Post: 2013-07-16, 09:14 AM
  2. Error closing dwg files
    By amaser in forum Dot Net API
    Last Post: 2011-05-19, 02:34 PM
  3. Error on closing Autocad
    By aquaman in forum VBA/COM Interop
    Last Post: 2009-01-29, 11:31 AM
  4. Closing Autocad fatal error
    By jjacoby in forum AutoCAD General
    Last Post: 2005-06-11, 09:02 PM
  5. runtime error ...after closing acad
    By ironwood1957 in forum VBA/COM Interop
    Last Post: 2005-03-04, 10:22 PM
