Thread: Excessive Annotation Scales
    I could stop if I wanted to andy.manninen's Avatar
    2015-10
    @ _ork
    304
    Exclamation Excessive Annotation Scales
    By using the command scalelistedit or by making a new command button in the CUI with the macro “^C^C(command "-scalelistedit" "r" "y" "e")” you can easily wipe out excessive annotation scales. Maybe even adding this into your custom toolbar or pulldown menu? Or if you really want to hammer the lists, add the command to your ACADdoc.lsp file so it runs every time you open a DWG. (if this makes does not make sense, then please do not attempt to modify any AutoCAD files!!!)
    See attached PDF for pictures and everything!
    :Cheers:
    2015-10
    @ _ork
    304
    Default Re: Excessive Annotation Scales
    Or download AutoDesk's batch utility, to be able to grab by folder or individual dwg...
    http://usa.autodesk.com/adsk/servlet...linkID=9240658
    :Cheers:
  1. Replies: 10
    Last Post: 2022-08-25, 10:06 PM
  2. excessive annotations scales in Layouts
    By mk144390 in forum AutoCAD Annotation
    Last Post: 2011-04-08, 06:58 AM
  3. Annotation scales=lag
    By spturner600 in forum Vault - General
    Last Post: 2009-08-20, 01:22 PM
  4. Purge Annotation Scales That Are Not the Current Active Annotation Scale
    Last Post: 2009-02-01, 06:04 PM
  5. Annotation Scales and Viewport Scales
    By Shizzjr in forum AutoCAD General
    Last Post: 2008-10-24, 05:42 PM
