Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: A Road Tool, Re-confurable key menu, and SketchUp ??
    I could stop if I wanted to Richard McCarthy's Avatar
    2003-07
    237
    Default
    1. A Road Tool, that you just define the width (and also cross section shape) and draw the path/spline on the plan view, and it will automatically be attached and conform to the terrain. (Sort of like the tools they have in Command and Conquer General Editor)
    2. Re-confurable key menu. This is desperately needed. Every other app worth it's salt have it, why revit doesn't??
    3. Draw along surface spline tool, so you can "extrude" shapes out of terrain, eg. fences, post, etc.
    4. SketchUp like interface - I must be dreaming about this every night... just basically let you draw lines in 3D space that snap to the 3D axis and form 3D faces. Revit's family editor badly need this for easier family creation. Also a more powerful polygon tools (like from MAX) are needed too for more complex editing/object creation.
    -RM
    All AUGI, all the time janunson's Avatar
    2003-07
    Grand Rapids, MI
    650
    Default Re: A Road Tool, Re-confurable key menu, and SketchUp ??
    about number 2... I believe that's already there (you mean the quick key commands, right?)
    check C:\Program Files\Autodesk Revit 5.1\Program\KeyboardShortcuts.txt.
    2003-07
    237
    That's a the horrible way to edit your keyboard short cut. Like some unfinished backend interface, looking for that particular files EVERY DAMN TIME I need to reconfigure some key. Why can't autodesk write a proper menu for it? SketchUp have it, most apps have it, even GAMES have an easy to use and definable key menu. WE DON'T want to hack around a txt file to get it done.
    2003-07
    237
    I just remember, another thing,
    JOURNAL playback needs to have a fast-forward and rewind button, or a button to click through each steps then pause, AND a pause button.
    Also a menu for history (like photoshop) where you can click the steps back or just scroll through the command list. Maybe even support multi-path history..... (I am dreaming here now)
    All AUGI, all the time jbalding48677's Avatar
    2003-05
    Irvine, CA
    765
    Quote Originally Posted by Richard McCarthy
    It seems to me that this could be integrated somewhat easily, it just needs to be prioritized at Revit. Your wish has been noted.
    Now, there is really no need to get so angry about it. Just ask and move on.
    - JB
    2001-12
    Irvine, CA
    7,567
    This has never bothered me, but then I guess I was used to it since there were many such files requiring upkeep with that "other" software.
    I think a "nicer" way to add your own would be nice, but not a priority for me.
    Someone recently compiled a shortcut file that has virtually all the possible commands in it...you just add shortcuts to any commands you'd like and you're done. Save a copy and after an upgrade pop it back in...
    Want to see it for your self? Click ME It's the one with the BD prefix.
    2003-07
    Grand Rapids, MI
    650
    wimp.
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    I have made a shortcut to this file in my projects folder and can get to it pretty easily. I don't find it that hard to work with...that said, an alias editor ala autocad express tools would be neato.
    2003-07
    237
    hehe, I just like to try out the "evil" icon from time to time
    AUGI Addict hand471037's Avatar
    2003-05
    Oakland, California
    1,934
    A feature that I loved from Truespace is that you can edit the shortcuts by either going to a shortcut .txt file (ala Revit & AutoCAD) -or- (and this was the cool part) simply hit 'alt' & 'F2' (or something like that), select a tool, then hit your choosen keyboard combo and BAM! shortcut established for that tool/setting. It was great having this shortcut-defining 'prefix' for it made it trival to set shortcuts on the fly... if you did something more than three times in a row, you'd simply set a shortcut and get on with your work. it saved these shortcuts to the .txt file too, so that you could go back later and ditch them/rework them...
  1. Replies: 1
    Last Post: 2013-03-16, 11:35 AM
  2. menu tool bar
    By leo.cortesini in forum AutoCAD Map 3D - General
    Last Post: 2009-07-28, 08:35 PM
  3. Tool on the menu bar
    By sherflor in forum AutoCAD Customization
    Last Post: 2008-01-05, 04:17 AM
  4. A Road tool??...Shape conform to surface then extrude tool?
    By Richard McCarthy in forum Revit Architecture - Wish List
    Last Post: 2004-08-30, 12:49 PM
