Results 1 to 9 of 9
Thread: Output pixel dimensions
    2004-03
    19
    Default Output pixel dimensions
    I noticed that in Revit 2009 they removed the ability to manually change the DPI and pixel dimensions of a rendered image. Does anyone know how to do this?
    A few other comments: In previous versions I used to render a 3000 pixel wide image at 300 dpi in about 20 minutes. Now in 2009 the highest quality image is only 900 pixels wide for the same size viewport and takes an hour to render. Is the increased raytracing quality the cause of this or am I doing something wrong?
    Thanks
    2004-06
    Memphis TN area
    7,048
    Default Re: Output pixel dimensions
    The number of pixels of the rendered image depends upon both the selected DPI, and also the size of the viewport crop region.
    If you got an image 3000 pixels wide at 300 dpi, then the viewport must have been 10" wide. Click on the view's crop region, and you'll see a button at the top where you can change the size of the view (without changing the actual camera position or angle). When you first create a perspective camera view, the default viewport size is 6" x 4.5" I think. So you click that button, and you can change it while maintaining the view's aspect ratio.
    2003-09
    1,907
    You can directly set the DPI and size by using the plot setup vs screen. Do not recommend it unless you must have a very high resolution image, and you have PLENTY of time- talking days here.
    I could stop if I wanted to Chirag Mistry's Avatar
    2004-06
    Atlanta
    254
    Yes you can !
    For Size:
    Select the crop region of the view and the size appears on the option bar, click it to change .
    For DPI:
    In the render dialog box select Custom (view specific) under the quality category, then select Printer under output setting and just type in the DPI value in the pull down
    Revit Founder LRaiz's Avatar
    2003-07
    Newton, MA
    714
    Back in the days of Accurender the DPI parameter was a bit confusing and I suspect the info below applies to a new renderer as well.
    It is not really a printer DPI (which is defined by hardware). DPI in a render dialog refers to density of rays computed during rendering process. I'd call it raytracing DPI. Once rendering is computed raytracing pixels are used to interpolate physical pixels of a screen or a printer.
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    I think what people are after is getting the pixel dimension bigger so that when it prints, it looks nice and sharp. Using the "Output Printer Resolution" does that.
    But, what you are saying is that along with simply making the pixel dimensions bigger, it's also increasing the density of the rays? Maybe that would help explain why increasing the dpi settings appears to increase rendering times so much?
    Quote Originally Posted by LRaiz View Post
    2004-06
    Memphis TN area
    7,048
    hmm well all I know is that a 3D scene with crop region set to 6" wide and DPI set to 150 is going to yield an image that is 6*150 or 900 pixels wide. If I change it to 300 DPI, the size of the resulting image doubles to 1800 pixels wide.
    2002-02
    St. Louis, MO
    4,695
    Quote Originally Posted by patricks View Post
    ...resulting image doubles to 1800 pixels wide.
    ...which is quadruple file size and quadruple rendering time. Not just double.
    2004-06
    Memphis TN area
    7,048
    yea I know, 4 times the area. I meant the width in pixels doubles if you double the DPI setting.
  1. jpg export >2048 pixel
    By dp.147682 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-11-11, 03:16 AM
  2. Google Earth and Pixel Size Representation
    By Opie in forum Software
    Last Post: 2007-08-24, 06:39 PM
  3. editing raster image with different pixel size
    By gisdude in forum AutoCAD Map 3D - General
    Last Post: 2006-05-11, 06:42 PM
  4. Export 10K pixel limit - why?
    By mschroeder in forum Revit - Rendering
    Last Post: 2005-12-09, 08:20 PM
