Results 1 to 10 of 15
Thread: Room Tags in Revit MEP 09
    100 Club phil.pleiss's Avatar
    2007-10
    Denver, CO
    105
    Default Room Tags in Revit MEP 09
    In 08 when you copy/monitor a linked file there is an option to copy the room information (to place room tags). In 09 there is no option to copy the room information when using copy/monitor. Is there an easy way to copy the room information so that room tags will automatically come in with the room name/number?
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    Default Re: Room Tags in Revit MEP 09
    Quote Originally Posted by phil.pleiss View Post
    2009 uses spaces now, which links information from rooms in the arch model to it. You now need to use a space tag (and place spaces) in your project.
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
    2008-04
    Missouri
    52
    You will also need to manually place spaces in each of the rooms individually before you can tag them.
    All AUGI, all the time kyle.bernhardt's Avatar
    2005-10
    Inside the Factory
    705
    Quote Originally Posted by sec-k View Post
    Which I might add, that you can do inside of the HVAC Zone editor, for a streamlines workflow. I have a blog entry on this subject.
    Cheers,
    Kyle B
    Product Line Manager
    Revit Services
    Smart Questions = Smart Answers
    2004-06
    144
    We modified the default Space Tag to show the "room" name and "room" number. The default tag wants to list the "space" name & number, the "room" info is added automatically from the architectural link.
    Also, is there a way to adjust the MEP tramplate so that any Revit links are automatically "room bounding"?
    2005-10
    Inside the Factory
    705
    Quote Originally Posted by UpNorth View Post
    For performance concerns, no. You will need to enable that functionality for each link.
    Cheers,
    Kyle B
    Revit Services
    100 Club sfraney's Avatar
    2004-07
    Philadelphia,PA
    198
    I'm trying to understand this. So is there a way to show the architect's rooms and room numbers in REVIT MEP via linked file?
    Or does one need to manually type the room name and room number into EVERY space object?
    If this is the case then, how does Revit MEP 2009 keep track of when I change a room name or a room number in the architectural model? One needs to update this manually inside Revit MEP 2009 by renaming the space object???
    2007-03
    890
    Quote Originally Posted by sfraney View Post
    The spaces still see the room name/number. When you create a tag you can use a label of those parameters and not even bother with space name.
    Space name/numbers only seem to have a use in places where a room is divided into multiple space, or potentially in a plenum or something.
    Baltimore, MD
    2001-12
    Irvine, CA
    7,566
    Quote Originally Posted by mjdanowski View Post
    ...Space name/numbers only seem to have a use in places where a room is divided into multiple space, or potentially in a plenum or something...
    That and when using the Heating and Cooling Loads tool because the Space data, not room data, is what is displayed there.
    2004-07
    Philadelphia,PA
    198
    Figured out a great way around the Room Tag issue:
    Edit the Space Tag in Familt Editor:
    Click the actual Tag itself (it should turn red", then
    Click "Edit Label" button at the top menu
    Add Room Name and Room Number, Area, etc. parameters to the Space tag
    Delete the "Space Tag" parameter
    Viola, Room Tag!
    You'll still need to add a Space Object to each room though.
  1. 2014: Elevation tags not finding room boundary when placed over Revit link
    By Mhug9 in forum Revit Architecture - General
    Last Post: 2014-09-08, 01:53 PM
  2. 2013: Revit Architecture - Room Tags on Second Floor
    By ROBP-RDS in forum Revit Architecture - General
    Last Post: 2014-05-27, 02:43 AM
  3. 2013: Room Tags and Annotation Crop; Visibility Graphics for Revit Links
    By greyghost1984 in forum Revit Architecture - General
    Last Post: 2012-10-26, 07:06 AM
  4. Rooms & Room Tags in Revit Structure?
    By Beaglemommy in forum Revit Structure - General
    Last Post: 2012-07-22, 03:39 PM
  5. Room Schedule/ Tags/ Room-Advanced
    By bpaul in forum Revit Architecture - General
    Last Post: 2007-03-15, 01:45 PM
