(x-posted to Autodesk forums)
1. How are wiring lengths calculated in RME? Does it count the wire going down to the receptacles from the ceiling? Does it go around doors? Refer to this post on AUGI:
http://forums.augi.com/showthread.php?t=65672
2. Are the electrical calculations based on any methodologies/standards from National Electrical Code (NEC)? Can I change any of the calculation methodologies/standards to suit local jurisdiction requirements (ie. Ontario Electrical Safety Code)
3. Is it possible in RME 2009 to specify a tolerance around the object to include in the interference checks (ie. 1 inch around ducts to provide for insulation?)
any help is appreciated. Thanks.
