Thread: very large master plan issues
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Question very large master plan issues
    Anyone have any ideas how to show large amounts of tree masses
    in a very large (600 plus acres) master / site plan?
    RPC trees seem out of the question due to large quantity--performance issues,etc.
    The tree masses are mostly existing conifers--in very dense forest areas.
    They need to look realistic--so I can't really "fake" them...
    There will be golf courses, lakes, roadways, parking, campus of bldgs., etc. as well.
    The revit site tools are very problematic--esp. using large subregions/split surfaces, etc.
    The model will be used for presentation/renderings, and eventually
    brought into 3dMax for animations,etc. However, we would prefer to model everything
    in revit, and import fbx into max.
    Anyone suggestions from anyone who has done this type of large site before most appreciated.
    Thanks...
    Pittsburgh, PA USA
    1,906
    Default Re: very large master plan issues
    [quote=The model will be used for presentation/renderings, and eventually
    in revit, and import fbx into max..[/quote]
    The best advise is to do one of two things. Best solution would be to place the trees once you are in 3DS Max. Second would be to place the trees in another file, link it into the main model. That way, you'll be able to "unload" the tree model when you do not need it, to speed up responce time.
    2002-02
    St. Louis, MO
    4,695
    Building Revit.
    Site 3DS Max
    Revit just deosn't do a good job on complex site 3D master planning. It works OK for 2D.
    2004-05
    St. Louis, Missouri
    3,135
    Question Re: very large master plan issues
    Thanks--agreed. Splitting into separate files is an absolute requirement--
    at a minimum the entire site as a link, buildings a link, etc.
    However, the real issue is WHAT KIND of trees to use--RPC, Marlin Studios, etc.
    or some other low-poly type of tree for mass / dense foliage on a very large site.
    In 3dsMax, we can use Mental Ray "proxies" of RPC trees, but there are some apparent issues/problems w/ texture mapping, shadow plug-ins, etc.
    Any tips, anyone?
    Cheers.....
  1. 2016: Plotting issues with large dwg files and surfaces
    By stevej.57608 in forum AutoCAD Civil 3D - General
    Last Post: 2015-06-18, 08:24 PM
  2. Placing buildings into master site plan
    By fernandez in forum Revit Architecture - General
    Last Post: 2009-11-05, 02:06 AM
  3. Replies: 9
    Last Post: 2008-06-25, 02:51 AM
  4. Large Core Plan Problem
    By Steve Hutana in forum Revit Architecture - General
    Last Post: 2006-05-23, 12:03 AM
  5. Issues with Documenting Very, Very, *Very* Large Buildings in Revit
    By dcunningham in forum Revit - In Practice
    Last Post: 2006-04-17, 02:57 PM
