Thread: Trim is not Trimming whole line...
    2004-11
    35
    Default Trim is not Trimming whole line...
    I had this problem in the past and I think its a variable.
    When I do the trim command and just hit enter to pick everything as a cutting object, it only trims little pieces of the line. It appears that it is picking items as cutting objects although they aren't even cutting through the line I'm trying to trim.
    Does anybody know how to fix this.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,089
    Default Re: Trim is not Trimming whole line...
    EDGEMODE set to 0 should help you.
    2004-11
    35
    That was the variable I was looking. Worked perfect !
    Thanks !!
  1. Trim or extend line to line - dynamic block
    By janandraczko in forum Dynamic Blocks - Technical
    Last Post: 2009-03-02, 12:33 AM
  2. Trim not trimming, extend not extending
    By Kimberly Fuhrman in forum AutoCAD General
    Last Post: 2008-02-15, 01:52 PM
  3. Trim not trimming back to selected trim boundary
    By Wwhite72082 in forum AutoCAD General
    Last Post: 2007-03-23, 01:47 PM
  4. Trim and Extend, trimming back, extending, too far
    By Mamma Jamma in forum AutoCAD General
    Last Post: 2006-10-31, 09:33 PM
  5. Improvement to Fillet & Chamfer trimming/no trimming options
    Last Post: 2006-07-12, 03:00 PM
