Thread: ACAD MEP 2009 Object Enablers for ACAD LT 2009
    Active Member seventwo's Avatar
    2007-02
    (415)
    95
    Default ACAD MEP 2009 Object Enablers for ACAD LT 2009
    I'm trying to make the switch for the CAD department to AutoCAD MEP 2009.
    My problem is, our engineers are using AutoCAD LT 2009 and I can't seem to get the object enablers to install.
    I downloaded this, but it gives me an error stating the proper software is not found.
    http://usa.autodesk.com/adsk/servlet...linkID=9240938
    Any ideas?
    2003-10
    San Francisco CA
    1,190
    Default Re: ACAD MEP 2009 Object Enablers for ACAD LT 2009
    Hi seventwo,
    It doesn't look like the MEP object enabler for LT is available yet.
    http://usa.autodesk.com/adsk/servlet...linkID=9240818
    The 2008 LT Object Enabler can be found here.
    You might try loading it. It looks like the link you provided is for Vanilla CAD and not LT.
    Hope this helps,
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    Active Member drafting1's Avatar
    Atlanta, Ga
    84
    Thumbs down Re: ACAD MEP 2009 Object Enablers for ACAD LT 2009
    Seventwo,
    The autodesk website said to contact my reseller for infomation on the object enablers.
    My reseller told me to contact Autodesk.
    Autodesk then told me to contact my reseller....and around we go!
    Talk about customer no-service.
    Finally I was advised thruough my reseller that they could not say when
    the object enablers for AutoCAD Lt 2009 would be released and that I
    should continue to use 2008 until the enablers are available.
    The problem is I spent a day at the jobsite to get them set up using 09 and
    they don't have 08.
    The concensus is that we wasted our money.
    We shall see....
    Maybe I should switch to using Revit...although it isn't ready either.
    Mike Bradford
    I could stop if I wanted to ameador's Avatar
    2006-02
    424
    I spoke with my reseller and we found where the object enablers are for the 09 products. Unfortunately, I do not see anything for the LT versions.
    Here's the website I am looking at:
    Keep in mind if you have a 32 bit system or a 64 bit system you'll have to choose the correct item to download.
    CAD user since '95, CAD Mgr since '07, BIM Lead, Mech Eng
    R10, R14, 2000i, 2002, 2004, ABS 2007, AMEP 2009, 2011, 2012, 2013, 2014, 2015
    RMEP 2011, 2012, 2013, 2014
    REVIT 2015, 2016
    Author of: http://ab-nerd-disc.blogspot.com/
    2007-02
    (415)
    95
    Thanks all, for your input...
    That's a no-go on the ACAD 2008 enabler.
    Ugh!
  1. Check in from Acad 2009 locks up Vault 2009
    By Mike Y in forum Vault - General
    Last Post: 2009-02-23, 08:54 PM
  2. Object Enablers not working with AutoCAD 2009
    By marcusnewport in forum AutoCAD General
    Last Post: 2009-02-23, 11:18 AM
  3. Mtext Issues Acad 2007 to Acad 2009
    By Eddy B in forum AutoCAD General
    Last Post: 2009-02-13, 12:37 PM
  4. ACAD / C3D 2009 Object Enablers
    By billy342601 in forum AutoCAD General
    Last Post: 2008-09-02, 04:33 PM
  5. NON-ACAD object enablers
    By jgratton in forum AutoCAD General
    Last Post: 2005-05-05, 04:51 PM
