Thread: Menu Fatal Error:
    Member dbanker's Avatar
    2002-12
    Mushroom Capital of the World
    47
    Default Menu Fatal Error:
    Has anyone ever seen this error:
    • Menu Fatal Error: End Element Was Missing The Character '>'.
    It's happening in ACA 2009. The right click menu doesn't work in the drawing area and the only pulldown menu's i see are 'File', 'Window' and 'Help'.
    For some reason it can't read the ACA.cui. It's in the correct folder and pointing to it. It's not a permissions issue (i'm 95% sure...).
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Menu Fatal Error:
    Sounds like a need for a clean install.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2008-08
    I am having the exact same trouble. Autodesk worked fine yesterday, this morning my right click is not working, seeing only File Window Help pulldowns and when it loads, the same error message "Menu fatal error: End element was missing the character '>'."
    Did you end up reinstalling the program or were you able to repair it some other way
    2002-09
    Madison, WI
    5,685
    I would try a registry repair first. Then I'd go with the clean install.
    If you need info on the how to fir the repair, let us know.
    2010-06
    Omaha, Nebraska
    32
    Menu fatal error: A name contained an invalid character.
    I am hving similar trouble in ACAD 2007. However, my error reads as follows:
    I have spent a lot of time customizing this .arg and .cui. I would like to not have to rebuild it, but I may not have a choice. I would like to know what worked for previous posts and how the issue was resolved. Before I go and reset my ACAD.
  1. 2012: Revit mep: Export to dwg fatal error. Sync fatal error as well
    By Scottybill in forum Revit MEP - General
    Last Post: 2012-11-30, 09:47 PM
  2. Replies: 7
    Last Post: 2010-11-22, 06:30 PM
  3. Replies: 14
    Last Post: 2008-09-05, 09:56 PM
  4. Fatal menu shut down?
    By CADMama in forum AutoLISP
    Last Post: 2007-10-11, 02:39 PM
  5. Replies: 2
    Last Post: 2005-11-04, 01:46 AM
