Thread: Slope piping system problem
    2008-04
    London, UK
    16
    Default Slope piping system problem
    Good Morning all,
    I have overcome a great problem concerning sloped piping system in MEP. As presented on Image_01 there is main branch of SVP up to which number of another sloped pipes are attached. All of them are sloping at the ratio of 1:10. If I start editing the main branch of the created system (nudge it it to the left or to the right) all the other pipes that are attached to it do not update as presented on Image_02.
    The only way I managed to solve this was to later update every single branch manually what means that with every change done to the main branch modelling of each sub-branch must be done, what seems to be an endless process.
    Is there any solution to this situation or unfortunately Revit MEP is yet still not capable of handling such a complex task (number of slopes, levels, pipe lengths etc)?
    MarcinM
    I know I can do it and I will....
    All AUGI, all the time kyle.bernhardt's Avatar
    2005-10
    Inside the Factory
    705
    Default Re: Slope piping system problem
    Marcin,
    I'm not sure why your connected piping is not updating according to the changes in the main branch. I've asked our Quality Assurance team to follow up on this item.
    Cheers,
    Kyle B
    Product Line Manager
    Revit Services
    Smart Questions = Smart Answers
    2008-05
    5
    Marcin,
    I am a member of the Revit MEP QA group. I have not been able to reproduce your issue. Could you provide me with a list of exact steps and a copy of your dataset? You can contact me at greg.gagnon@autodesk.com.
    Greg
  1. Replies: 10
    Last Post: 2016-06-27, 12:04 AM
  2. 2013: Revit 2013 Slope Piping tools - Disappear
    By rvzenteno in forum Revit MEP - General
    Last Post: 2013-05-08, 04:07 PM
  3. Equipment for a piping system - Problem
    By E-Key in forum Revit MEP - General
    Last Post: 2012-07-10, 03:28 PM
  4. Piping System Flow Problem
    By WT-09 in forum Revit MEP - General
    Last Post: 2011-12-19, 08:58 AM
  5. Replies: 0
    Last Post: 2011-11-22, 01:49 PM
