Thread: Custom Schedule...
    I could stop if I wanted to scowsert's Avatar
    2006-08
    Olympia, WA
    418
    Default Custom Schedule...
    I'd like to recreate this AutoCAD (I know i know...) schedule in Revit. It doesn't have to be smart. Up too now I've been doing this with linework as a detail. Is there a better way? Can I do the oval symbol in the left in a Schedule (I don't think I can)?
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    Default Re: Custom Schedule...
    I don't know of any way to embed the oval mark, but other than that, it looks like a fairly typical schedule. If you absolutely have to show the oval mark in the schedule, you can add it with detail lines on your sheet and then array it. I frown on that kind of thing, but it might still be better than constructing the whole thing with detail lines.
    2007-06
    49
    Quote Originally Posted by iru69 View Post
    No you can't. Detail lines have to be in a view and cannot be placed on a sheet.
    I don't believe this can be done.
    JB
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Quote Originally Posted by justin.black View Post
    Detail lines can be added to a sheet.
    ______________________________________________
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    2001-12
    Irvine, CA
    7,566
    You can make a "block w/ Attributes" either as a fixed size table or a header and data rows. You start with a Generic Annotation Symbol, draws the lines and add labels/parameters for each value you want to enter. When you put this in the project is will be a symbol family that will let you enter the values when you select it, assuming the parameters are instance based. As pictured in the example image.
  1. Custom schedule
    By amindez9667 in forum Revit Architecture - General
    Last Post: 2009-04-08, 07:08 PM
  2. custom 8 1/2 x 11 schedule
    By cliff collins in forum Revit Architecture - General
    Last Post: 2009-02-18, 06:20 PM
  3. Custom Schedule
    By rkc in forum ACA General
    Last Post: 2008-08-02, 09:38 PM
  4. Custom Room Schedule
    By rbraunthal in forum Revit Architecture - General
    Last Post: 2007-10-19, 02:07 PM
  5. revit custom schedule style
    By jamie.casile80054 in forum Revit Architecture - General
    Last Post: 2006-01-17, 05:16 AM
