Results 1 to 7 of 7
Thread: Quick adding of multiple closed polyline areas
    2002-02
    12
    Default Quick adding of multiple closed polyline areas
    Hi,
    I am working on large site development with lots of independent landscaped areas.
    I currently use the AREA command routine to add them all up.
    Does anybody know of a routine that would allow me to select all the closed polylines and return their total area?
    Thank you for any input in that matter
    Cord Blendermann
    2015-12
    Arizona
    2,478
    Default Re: Quick adding of multiple closed polyline areas
    Cord,
    If you had access to MAP you could query all those areas
    and export the results to excel and or label them in about 45 seconds.
    I know you asked for lisp, this is just another option.
    2002-02
    12
    Talking Re: Quick adding of multiple closed polyline areas
    Thanks for the replies, the LISP routine worked great.
    Good Day to ALL
    Cord b.
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Chelan WA
    1,088
    Post Re: Quick adding of multiple closed polyline areas
    Another way using activex and including circles and ellipses
    Peter Jamtgaard
    (defun C:plArea (/ intCount entSelection lstEntity objSelection
    	 ssSelections )
     (princ "\nSelect Polylines: ")
     (setq ssSelections (ssget (list (cons 0 "*polyline,circle,ellipse")))
    	   sngTotal	 0
     (repeat (setq intCount (sslength ssSelections))
      (setq intCount	 (1- intCount)
    	entSelection (ssname ssSelections intCOunt)
    	objSelection (vlax-ename->vla-object entSelection)
      (setq sngTotal (+ sngTotal (vla-get-area objSelection)))
     (princ "\n")
     (princ sngTotal)
     (princ " sq. inches")
     (princ "\n")
     (princ (/ sngTotal 144.0))
     (princ " sq. feet")
     (princ)
    2007-11
    2
    Is there a way to only choose the area of a polyline on a certain layer? I am assuming (because I am fairly new to this) that the 0 is dxf for type of entity. How would I query for all polylines', circles' and ellipses' area on the layer FPL-Area? Thanks. I hope this makes sense.
    Sassy
    Earth
    9,803
    Quote Originally Posted by susanr View Post
    Sassy
    Rather than add on to a 3.5 year old thread, you might have better luck posting a new thread.
    But to answer your question with psuedocode
    Use (ssget) with filters to filter out polylines, circles and ellipses on the layer FPL-Area layer.
    Then iterate this selection set, querying the area of each object and adding to the total.
    R.K. McSwain | CAD Panacea |
    2007-11
    2
    Thank you.
    Sassy
  1. 2015: Adding the same contour polyline to a surface multiple times
    By dpresley58437170 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2015-02-27, 05:01 AM
  2. Replies: 6
    Last Post: 2014-07-12, 08:07 AM
  3. ssget closed polyline
    By rad.77676 in forum AutoLISP
    Last Post: 2009-04-16, 07:26 AM
  4. C# - closed Polyline length
    By RoSiNiNo in forum ARX
    Last Post: 2005-03-02, 03:17 PM
  5. Getting the centroid of closed polyline
    By csgohjmj in forum AutoLISP
    Last Post: 2004-10-15, 06:01 AM
