Results 1 to 7 of 7
Thread: File Paths
    2004-08
    Syracuse, NY
    631
    Default File Paths
    I have been in the process of revapamping our AutoCAD network drive which meant a new drive letter designation. My question is, do the network drive path designations for AutoCAD only exist as part of the user profile? when I release this, I would like to do this in a way where I reset the directory paths, but not the users' interface. I thought of a script file, but I do not see how this would work without resetting the users' interface/ profile.
    Any thoughts or suggestions would be appreciated.
    Thanks
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Re: File Paths
    Assuming you have a set of customizations on your server and want to remap existing installation to this, you may find this utility usefull: http://www.cadwerx.net/?path=AcadInstall
    Otherwise you could modify the ACAD registry value through a SCRIPT using the LISP
    (getenv "ACAD") and (setenv "ACAD" ...) by finding the old value and replacing with the new. Possibly use the (vl-string-subst ...) function for this.
    And then I'm guessing your biggest problem would actually be XRefs. For this I'd suggest using the Reference Manager (installed together with AutoCAD). You can find it under the Start Menu --> All Programs --> AutoDesk --> AutoCAD 200# --> Reference Manager.
    2006-02
    424
    Just a quick comment on the Reference Manager...I don't know what version you are using, but I do know that the Ref Mgr is broken in ABS07 and 08. I don't know if it has been fixed in 09.
    See comments on this poll:
    http://forums.augi.com/showthread.php?t=57345
    2004-07
    Detroit Michigan
    2,508
    Random thought:
    I am always worried about AutoCad not being able to find the correct network drive.
    Would it be helpful to change the newtwork drive on a whim while having each computer map a drive letter to the correct network drive?
    The user could map "P:Autocad" to any network location.
    2015-11
    Jo'burg SA
    4,512
    That's always a problem. The only way of getting around is relative paths.
    2005-06
    in the upper right corner
    3,523
    Quote Originally Posted by irneb View Post
    ^^ I totally agree, we use Relative Xref Paths for this reason.
    As long as you keep the same folder naming and hierarchy, it doesn't matter where they live.
    2006-02
    424
    Relative pathing should also help if you pass dwgs off (that have xrefs in them) to other companies that don't have the same letter pathing that you have.
  1. 2010: File paths and Profiles
    By csorensen in forum AutoCAD General
    Last Post: 2013-08-09, 05:52 PM
  2. Deployment file paths problem. File paths cannot be customized
    By robertlevy493178 in forum AutoCAD Customization
    Last Post: 2013-01-02, 04:13 PM
  3. Relative file paths?
    By thomas183523 in forum NavisWorks - General
    Last Post: 2010-01-18, 05:23 PM
  4. Replies: 19
    Last Post: 2007-10-17, 03:11 PM
  5. Relative file paths for images
    By monty.99416 in forum AutoCAD General
    Last Post: 2005-11-18, 04:49 PM
