Thread: Is there a way to view an .arx file?
    2002-12
    30
    Default Is there a way to view an .arx file?
    We have a Doc management system that has gone by the wayside and is not compatible with R2005. I think that the arx file links the database to the dwg file. The arx file will not load in R2005 so I thought it might just take a minor change (hopefully) to make it compatible.
    Thanks for your help!
    Mike
    Turlock, CA
    5,682
    Default Re: Is there a way to view an .arx file?
    An *.arx file is the compiled version of C++, basically a dll using the ObjectArx libraries. You would have to have the source code to edit it...providing you know C++. BTW, sounds like you're talking about AMW. I just switched to Adept.
    C:> ED WORKING....
    2002-12
    30
    Actually it is Green Pastures Software Wedge. We are looking at going to AMW Meridian, but are trying to get by in the mean time. Is there some drawbacks to meridian that you had found? How is Adept?
    Turlock, CA
    5,682
    We are in the purchasing phase, havn't implemented it yet. Meridian is way to expensive for our size of 30+ users. Adept compares to Teamwork but is cheaper and customizable, and programable.
    C:> ED WORKING....
  1. View Tags in a Linked File
    By FrenchQuarters in forum Revit Architecture - General
    Last Post: 2011-05-19, 06:48 PM
  2. Open file to view/print only
    By jcarrillo.75185 in forum Revit Architecture - General
    Last Post: 2007-05-17, 08:37 PM
  3. How can I view a DWG file on my intranet
    By jasontirone in forum CAD Management - General
    Last Post: 2005-08-10, 09:16 PM
  4. File imported into which view?
    By mark_a in forum Revit Architecture - General
    Last Post: 2004-06-17, 04:34 AM
  5. How to view a Pan or IVR file?
    By Nevine in forum Revit - Rendering
    Last Post: 2004-01-09, 04:14 PM
