Thread: Slab Edge Profile not loading under Floor-Slab Edge
    2004-05
    Santa Barbara, Ca.
    40
    Default Slab Edge Profile not loading under Floor-Slab Edge
    Can't make a slab edge profile that is recognized by the Host Sweep -Floor Slab Edge tool.
    Using Profile-Hosted family template.
    In family categories and parameters, setting Profile Usage to Slab Edge.
    After loading the profile into the project it shows up in the Project Browser under Profiles and not under Floors, Slab Edge. The Host Sweep -Floor Slab Edge tool is listing profiles only from Floors,Slab Edge and not from Profiles.
    What am I missing here?
    John
    2004-06
    Memphis TN area
    7,048
    Default Re: Slab Edge Profile not loading under Floor-Slab Edge
    What is listed under Floors > Slab Edge is all the different defined slab edge types. Each type has a profile associated with it.
    So you need to duplicate one of the Slab Edge types listed, go into the properties and pull down the Profile box to change it to the profile you just loaded. You can also define the material of your new Slab Edge.
    2006-06
    Toronto, ON
    2,386
    Also, make sure your profile family usage is set to either Generic or Slab Edge. To check it, edit your profile family and go to Settings > Family Category and Parameters > Profile Usage. This will define on which categories the profile will be available.
    Andre Carvalho
    2004-06
    Memphis TN area
    7,048
    Yeah he said the profile was set to Slab Edge type.
    2004-05
    Santa Barbara, Ca.
    40
    Thanks All. Missing the obvious that day!
  1. Floor slab edge thickenings to align and slope with slab
    Last Post: 2015-09-09, 05:24 AM
  2. Slab Edge Profile
    By lucas in forum Revit Structure - General
    Last Post: 2012-02-10, 06:25 PM
  3. Why does this slab edge offset prevent it from joining to a floor slab?
    Last Post: 2010-10-25, 09:49 PM
  4. Slab Edge Profile
    By JCAST79 in forum Revit Structure - General
    Last Post: 2008-03-08, 04:36 PM
  5. Floor Slab Edge host sweep type on a sloped slab
    By gravelin in forum Revit Architecture - General
    Last Post: 2005-02-17, 07:47 AM
