Thread: Command to Isolate Object(s)
    ACAD Wish List Administration
    1,920
    Default Command to Isolate Object(s)
    Summary: The ability to isolate an object or set of objects, regardless of layers.
    Description: Could we please have a set of buttons which allow the user to isolate an object(s), without seeing or interfering with any other objects. then once you have finished modifying the object, use a button to bring all the objects back.
    These commands Are available in CADDuct Solids.
    How Used: This would enable users to isolate and work on solid objects, when the object is in the middle of a complex model.
    Feature Affinity: Drawing Tools 2D
    Submitted By: Mike Robinson on March 19, 2008
    100 Club sgoodmansen's Avatar
    2005-10
    Post Falls, ID
    118
    Default Re: Command to Isolate Object(s)
    Did you try right click - Isolate objects? This works for me in ACA, I don't have plain AutoCAD, but I'm sure it must have it as well.
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Quote Originally Posted by sgoodmansen View Post
    It is not a feature of vanilla AutoCAD, only verticals.
    2011-08
    4,581
    Exclamation Re: Command to Isolate Object(s)
    The wish has already been granted. This thread is closed to further posts.
  1. Layer Isolate command
    By jsnow in forum AutoCAD General
    Last Post: 2009-09-21, 09:27 PM
  2. Error with Isolate command
    By moshira_hassan in forum AutoCAD General
    Last Post: 2008-05-20, 10:35 PM
  3. Isolate Layer Command
    By cbmcad in forum AutoCAD LT - Wish List
    Last Post: 2005-05-11, 03:07 PM
  4. Isolate One Object
    By Jarod in forum Revit Architecture - General
    Last Post: 2005-03-13, 08:29 PM
