Hi,
my current project is a remodel of an existing building. I've drawn the existing building in the "Existing" Phase. Then I inserted new windows in the "New Construction" Phase.
I need to show the existing elevation and figured out that it matters a lot, whether the wall is set to be bearing or non-bearing [I am using structural truss elements for the roof, so I get the warning that I'm placing the truss on a non-bearing wall and get asked whether I want to change it to be bearing]. With the wall set to bearing, the elevation will show the outline of the windows that will be punched out of the wall [see picture]. The View Properties are set to "Existing" Phase and it doesn't seem to matter what Phase Filter I use, the outline will always show up when the wall shows up.
Why is that?
Does it matter if I set a wall not to be non- bearing even if it is bearing and then send that Revit model to my structural engineer? I know that elevations of existing buildings might not be very common, still I wonder if this is something to put on the wish list?
Axel
