CAD cowboy
Thank you for your reply. However, I am not sure that this addresses the aspect of multileaders that I am concerned with.
The solution that you posted, as I understand it, and best that I can tell, allows the landing to be adjusted vertically (left and right). What I am wondering is, is there a way to adjust the text horizontally (up and down) relative to the landing line. For example, assume that the mtext height is set to 0.18 inches, and the Line Spacing is set to Exactly, giving a seperation between text lines of 0.12 inches. With these settings, the multileader landing line is spaced 0.036 inches pelow the first (top) text line. What I would like to be able to do is change the position of the landling line between the text lines; for example, to exactly half way, or 0.06 inches. Is this possible, and if so, how do I go about it?
