I was working on a HVAC floor plan in which i was basically finished with my entire sheet. everything was running good and at some point many of the diffusers and dampers have disappeared on the screen. amongst switching from one window to another and returning to this particular construct many of the diffusers and dampers are no longer visible. it is not consisttant through out the drawing as it is totally random and some dampers and some supply diffusers are not totally visible. you can see everything fine if you switch to a 3d view. if you select the part and use the object viewer it seems fine. the program is reconizing that the part is there becase you can select it and change properties and then if you move it it still cannot be seen on screen but you can see the notation showing a nonconnection. you can also check the connection and it will say its connected and act as it is but just cannot view the part. these also do not print. I have tried most of the basic things to fix this but have came to a wall. if i put a new part in it still does the same thing.
any help is appreciated.
