Thread: Data Shortcut problem
    2006-02
    14
    Unhappy Data Shortcut problem
    I'm having an issue with a data shortcut. I have .xml files of an existing surface and a proposed surface that I inserted into a drawing. I created a reference for both of them and they show up in my drawing perfectly. All is well to this point. I then clicked the green check box to close the data shortcut dialogue box and save my drawing. After I'm done working in the drawing, I save and exit.
    Now when I open the drawing back up... The data shortcuts aren't in it. In the toolspace, under surfaces, it shows there is an existing and proposed reference in the drawing but if I try to synchronize them, I get the error "Reference for surface is broken". Now if I go into data shortcuts and reinsert the .xml files, the two data shortcuts will appear without me having to create a reference for them. Once I do this, the data shortcuts behave fine.... untill I exit the drawing of course.
    The weird thing about this all is my co-worker can open up the drawing on his machine and the data shortcuts will be there for him without him having to reinsert the .xml files like I have to do. It may be a setting that I have to change, can someone help?
    2006-02
    14
    Default Re: Data Shortcut problem
    This problem is starting to get pretty annoying, can anyone help?
    2008-03
    Maryland
    54
    are you using vault?
    is your profile saving the xml files properly before it closes out?
  1. Data shortcut for Corridors
    Last Post: 2014-11-13, 07:53 PM
  2. data shortcut in Map 3D?
    By dmingo in forum Geospatial - General
    Last Post: 2014-05-08, 01:03 PM
  3. 2013: Data Shortcut: Associate Project to Current Drawing Problem
    By GreyHippo in forum AutoCAD Civil 3D - General
    Last Post: 2014-04-25, 03:32 PM
  4. catchments need to be a Data Shortcut
    Last Post: 2013-08-12, 01:44 PM
  5. Data Shortcut Folder
    By mikeosborne in forum Dot Net API
    Last Post: 2009-11-24, 06:19 PM
