Having a Duh moment....
Now I know Chris will finally be able to get back at me for this one
A little history first. I formerly was at a company that used AutoCAD 2006 / 2007 and left there for a company that turned out had 2004. So, just as I was getting up to speed on DB's I lost a year of productivity
Well, I was able to convince our company to go for the AutoCAD 2008 MEP/Revit Suite and there was much rejoicing Yea!!!!
So now I am finally "TRYING" to get back up to speed on DB's and here is my question (A little long so please bear with me):
I have a blank drawing. I create a block. And save the drawing in my library as alpha.dwg (as an example)
Now I decide to make it Dynamic. So I open alpha.dwg and use the Block Editor to add my bells and whistles. Once done I hit Close Block Editor. Hit Save and close the drawing.
If I want to add the DB from alpha.dwg to my Tool Pallet, I use Design Center and drag that block from alpha.dwg onto the tab I want and all is good.
So now my question is... If I open alpha.dwg I click on Block Editor to edit the block.
But occasionally I get block drawings from others (AUGI Site or Chris the Block God) and when I open them there is a pop-up that says "BLOCK.dwg contains authoring elements. Open in Block Editor? Yes, No, Cancel" and if you hit yes it goes into the Block Editor and when I hit Close Block Editor it closes the drawing.
What makes one DB drawing open one way and what the other?
Clear as mud?
Thanks;
Red Dog
