Summary: A global save option for layer states, and saves with every viewport and every layout.
Description: Layer states should have a "Global" save option that saves with every viewport in every tabbed drawing in one operation.
How Used: This would save so much time and frustration when the user has 5 or more viewports per tab and 25 tab plus drawings in one dwg file.
This would be operated just before you do a plot run, knowing that all your drawings are set correctly at that moment and ready for issue. This layer state settings would then be archived into the issue folder, thereby if and when required the drawings are required would be plotted exactly the same.
Feature Affinity: Layer
Submitted By: Adye Goodenough on March 11, 2008
