Thread: Is it possible to draw a section that will only appear in the view you draw it
    2007-09
    174
    Default Is it possible to draw a section that will only appear in the view you draw it
    Hi,
    Is it possible to draw a section that will only appear in the view you draw it? For example if I take a section through my roof I only want the mark to show up on that view not on the floor below or any other sections. Is it possible to select the section and "hide in other views"?
    Jonas
    2006-06
    Toronto, ON
    2,386
    Default Re: Is it possible to draw a section that will only appear in the view you draw it
    You can create a scope box (Drafting menu > Scope Box) around the section mark and name it. The you select the section mark and go to Properties > Scope Box and select the scope box you just created. Doing that you are telling to Revit that that section mark will be controlled by the scope box. Now just go to a section view perpendicular to the section you want to hide in other views and drag the scope box extents to only be included in the level you want it to show. Also, dragging the extents of the scope box in plan to avoid it crossing other sections, will make the section mark not show on these sections.
    Of course, section marks are like a 3D object and only appear on views where its extents are crossing. If in a section view you change the extents of your section to just be included in between the level you want, it won't show on the other levels bellow.
    But I would use the first option (scope boxes)
    Andre Carvalho
  1. 2012: Draw Matchline in a Legend view?
    By ArchiN00B in forum Revit Architecture - General
    Last Post: 2012-08-09, 02:30 PM
  2. The ability to draw lines in a 3D view without selecting a workplane first.
    Last Post: 2012-07-09, 05:03 PM
  3. Make it possible to draw the current section box tool in a plan
    Last Post: 2011-11-26, 03:36 AM
  4. Can Not Draw Vertical Ductwork in Section or 3D View?
    By brainalien in forum Revit MEP - General
    Last Post: 2010-04-14, 06:11 PM
  5. Cross Section>Draw Template in C3D?
    By SRBalliet in forum AutoCAD Civil 3D - General
    Last Post: 2008-11-14, 04:38 PM
