mabrey
Open the elbow family and look at the "Lookup Table Name" parameter. The default one is 'Pipe Fittings.csv' I believe. Now browse to the location of the lookup tables which is specified in the Revit.ini file (default should be C:/Documents and Settings/All Users/Application Data/Autodesk/RME 2008/Lookup Tables), and make sure the appropriate .csv file is there.
The size of the sweep for the elbow is most likely determined by the "PipeOD" column in the .csv file and called "Radius" in the Revit family.
If it is still not working after this is verified, you might want to reinstall the family from either the web, or dvd.
-Jon
