Thread: Problem with basic dynamic block
    2007-08
    2
    Default Problem with basic dynamic block
    It's been a few months since i've created a dynamic block. My most common trick with the dynamic block is attributes that i can move and rotate. Pretty asic stuff. For some reason it doesn't want to work for me noew. Here's what I do.
    1.) create my attribute with ATTDEF
    2.) place a point parameter on the attribute
    3.) set a move action selecting my attribute and the point parameter
    This is where I have the problem. When I select the two I get this..
    "1 unlocked AttDef filtered from selection."
    I don't want it to be filtered from my selection!!! Needless to say, the move doesn't work when back in Model Space.
    100 Club wroebuck's Avatar
    2004-07
    Chico, CA
    158
    Default Re: Problem with basic dynamic block
    Is the attribute locked?
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by nscherneck View Post
    open your attribute's properties dialog and make sure that the location is set to locked. (locked "on" I believe).
    And reassociate the move. It should work then.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
  1. Replies: 0
    Last Post: 2015-03-20, 10:57 AM
  2. 2013: Dynamic Block Problem
    By terence.duggan1910 in forum Dynamic Blocks - Technical
    Last Post: 2013-09-20, 02:20 AM
  3. 2012: Dynamic Block Problem
    By i.e.dingle108402 in forum Dynamic Blocks - Technical
    Last Post: 2011-12-15, 01:46 PM
  4. problem with dynamic block
    By xlozano in forum Dynamic Blocks - Technical
    Last Post: 2009-08-24, 07:09 PM
  5. Having trouble with basic Dynamic Block concepts
    By tomcarver in forum Dynamic Blocks - Technical
    Last Post: 2006-11-17, 11:30 AM
