Thread: 2008 Migration problem
    Member KellyR's Avatar
    2004-12
    Ottumwa Iowa
    19
    Default 2008 Migration problem
    We recently just installed Inv 2008. After installing all the sevice packs I went to task scheduler and migrated the library file.
    I have done the get entire folder from vault so I have the latest on my hard drive. From what I can tell none of these files migrated. I have opened some of them and did a check out and then save and it is asking me to migrate the files that I thought I migrated over the weekend. According to the log that it generated they migrated.
    Any help would be great
    Member stanwile's Avatar
    2008-06
    Fort Mill, SC
    13
    Default Re: 2008 Migration problem
    Did you use the same Project file for the Task Scheduler that you use to login your Vault? If so I bet the Library files could not be updated because these files are locked.
    Try creating a “New” project file that looks to your Library as its “workspace.” I bet they will migrate then. You may already have a Library editing Project file created.
    Stan Wile
    2004-12
    Ottumwa Iowa
    19
    That is exactly what happened. After I created a new project file every thing worked great.
    Thanks
  1. 2012: migration problem
    By titameps437101 in forum AutoCAD LT - General
    Last Post: 2013-11-05, 01:14 PM
  2. 2008 forward migration of content
    By petervanko in forum Revit - Platform
    Last Post: 2009-07-30, 10:48 AM
  3. Migration from AutoCAD 2008 to 2009
    By U.Rackharrow in forum AutoCAD General
    Last Post: 2009-02-26, 02:21 PM
  4. Migration biliothèque 2008 vers 2009
    By Benoit D in forum Revit Architecture - Trucs & astuces
    Last Post: 2008-05-23, 10:54 AM
  5. Label style Migration: 2006 to 2008?
    By rdomke69 in forum AutoCAD Civil 3D - General
    Last Post: 2007-09-18, 11:02 AM
