Thread: foo.ARX is an invalid file.
    2008-07
    Exclamation foo.ARX is an invalid file.
    Hello,
    I have a project configured for Visual Studio 2002 (VC70) and ObjectARX 2005, when build to the out folder, the code generated its a resource.dll, and some .arx files, one have dependencies with the other, and compiles with no errors, but when i try to load the main arx file in Map 3D 2005, appear a message saying that the file is an invalid arx file.
    any idea to test if the ARX file is a valid version for Map 2005?
    Some wrong on DLL export table?
    Thanxs
    9,805
    Default Re: foo.ARX is an invalid file.
    While you wait here, you might try posting in the ObjectARX newsgroup over at Autodesk.
    http://discussion.autodesk.com/forum.jspa?forumID=34
    6,419
    What is the structure of your project? Is foo the name of your main dll, or a referenced dll?
    LinkedIn
  1. Invalid DBX file messages when opening a DWG file
    By Richard McDonald in forum AutoCAD General
    Last Post: 2014-02-17, 10:05 PM
  2. 2011: Invalid arx file
    By imacad in forum AutoCAD General
    Last Post: 2010-11-22, 06:31 PM
  3. Invalid I/O Type or File Name
    By terence.duggan1910 in forum AutoCAD Plotting
    Last Post: 2010-04-30, 03:28 PM
  4. invalid file ...
    By moshira_hassan in forum AutoCAD General
    Last Post: 2007-05-03, 07:06 AM
  5. CUI file has become invalid. What is the next step?
    By pcdesign in forum AutoCAD CUI Menus
    Last Post: 2006-02-28, 01:11 PM
