bob.86982
I am trying to create finish grading for my project on a sloped site, I imported the existing topography and created a topo surface. In the site tools I pick graded region, checked copy internal points, and picked select and edit.
This creates elevation points along my contour lines but if I move the points to create a cut or fill area it makes the contour line jagged between the other elevation points. The same thing happens if I add a new elevation point near the contour line to change its location.
I have 30 feet or more of slope across my building site with one foot contours so there are a lot of contours close together that need to be modified for the new cut and fill slopes.
This just does not work when I'm trying to make a smooth finish grade contour and it keeps adding these extra jagged segments in the line between the elevation points. also I can't figure out a way to place the finish contour lines such that I can create a defined slope for the cut or fill.
I can create my final site plan in autocad but I want to be able to show the finish grade in my 3-d model view.
Any help would be much appreciated.
