I am having problems with my section (and elevation tags) referencing the correct drawing sheet. The way I thought these tags were suppose to work is that the floor plan you place a section on should reflect the drawing sheet on which that floor plan is placed (or the drawing sheet on which the section is drawn).
Our project is being conducted in Phases and to fit the floor plans on a drawing sheet we are using dependent views. When I draw a section on a floor plan, the section references the correct drawing sheet on which the floor plan is placed. However, when I place the section view on a drawing sheet, the reference changes to reflect the first drawing sheet in the set on which a floor plan is placed.
Any ideas why this is happening? Is there some type of bug or defect?
