Thread: Can't install Impression
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default Can't install Impression
    I've downloaded Impression from the Autodesk Subscription site twice, once with Firefox, once with MSIE. Using either, I get the attached message, and I can't install. Is there a fix?
    2015-12
    Chesterfield, MI
    405
    Default Re: Can't install Impression
    Does the attempt to install extract all of the files to the designated folder or does it fail during the file extraction?
    Have you attempted to extract the files from the exe file (right click > extract to) and then run setup.exe from the extracted files? I've had luck with this method in the past when the original exe would "trip up" during it's extraction process.
    If you don't have an app loaded will extract outside of running the exe, I believe that WinZip and WinRar both have 30 day demos available that will accomplish this.
    Brett
    1,324
    Quote Originally Posted by bcgatti View Post
    Brett
    It seemed it was failing during the extraction. I downloaded WinZip and extracted the install files that way. All is good now.
    2015-12
    Chesterfield, MI
    405
    I'm glad that it helped.
    Brett
  1. GD315-2P: Using Autodesk Impression to ... Make an Impression!
    By Autodesk University in forum General Design
    Last Post: 2013-05-06, 01:36 AM
  2. GD32-1L: Making a Good Impression with Autodesk® Impression
    Last Post: 2013-04-17, 04:59 AM
  3. 2011: ACA 2010 - Install express tools after install
    By shane.249457 in forum ACA General
    Last Post: 2010-07-14, 03:15 PM
  4. Impression
    By dzatto in forum Software
    Last Post: 2008-06-02, 02:47 PM
  5. Fresh install or Install over?
    By Danny_Sim in forum Revit Architecture - General
    Last Post: 2005-01-26, 03:27 PM
