Results 1 to 7 of 7
Thread: Total polyline length
    2003-08
    31
    Default Total polyline length
    I need to add up the total length of all of the contours in an area. The contours are LDD contour objects. Does anyone know of a routine that will add the lengths of selected contours or polylines?
    13,656
    Default Re: Total polyline length
    Hi
    Below routine is from an old LISP Guild post by Stig Madsen -
    (defun C:PLINELEN (/ ent sset obj len sum layer a)
      (setvar "ERRNO" 0)
      (while
    	(and (not (setq ent (car (entsel "Select object on layer: "))))
      (/= (getvar "ERRNO") 52)
      (cond ((and ent
    	   (setq sset
    	   (ssget
    		 "X"
    		 (list '(0 . "LWPOLYLINE")
    		(cons 8 (setq layer (cdr (assoc 8 (entget ent)))))
      (setq a 0
    		sum 0
      (repeat (sslength sset)
    	(setq obj (vlax-ename->vla-object (ssname sset a))
       len (vlax-curve-getDistAtParam
    		 obj
    		 (- (vlax-curve-getEndParam obj)
    	 (vlax-curve-getStartParam obj)
       sum (+ sum len)
    	(setq a (1+ a))
      (princ (strcat "\nTotal length of "
       (itoa a)
       (if (= a 1)
    	 " pline on layer "
    	 " plines on layer "
       layer
       (rtos sum)
     (T (princ "\nNo plines found"))
    OR
    Check out something like the following -
    [size=2]]CADalyst Get the Code August 1999 - Pline Lengths
    Have a good one, Mike
    Arizona
    2,399
    You say LDD contour obects, if I take this to suggest
    that you have Land, and MAP at your disposal
    just use a MAP query of those objects, and set it to
    write a report of all the objects lengths in a comma delimited file
    and add them in Excel.
    2002-05
    39
    I copied the text to a text file, saved with a .lsp extension and used APPLOAD to load the application, however, I keep getting "Unknown command" ? when I type the new command name on the command line?.
    Using AutoCAD 2004
    Any ideas?
    13,656
    Hi
    Worked for me (just tested a few moments ago).
    * Copy & Paste Code into an ASCII text file (eg NotePad)
    * SaveAs PlineLen.lsp
    * Load into AutoCAD
    * At AutoCAD Command Line type PlineLen
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Quote Originally Posted by jbenway
    Just out of curiosity, why do you want to do that?
    2004-07
    Wink Re: Total polyline length
    It's grt...... I was about to create a lisp on my own... but i got a flash to check any post available related to my need....and I found this exactly meets my requirement... It saved me lot of time and effort..... Thanks for the creator......
  1. Replies: 9
    Last Post: 2015-05-03, 07:12 PM
  2. Total Length of Polylines
    By vijaybaskergundla in forum AutoLISP
    Last Post: 2015-04-30, 04:29 PM
  3. DIM Pline by total length?
    By cadtag in forum AutoLISP
    Last Post: 2014-08-04, 04:25 PM
  4. Polylines and Total Length
    Last Post: 2012-06-13, 08:10 PM
  5. Total Wall Length
    By jpolding in forum Revit Architecture - General
    Last Post: 2005-08-18, 03:17 PM
