Results 1 to 8 of 8
Thread: Batch Plot Style Change
    2007-08
    81
    Default Batch Plot Style Change
    Is there a way to change multiple layouts in a drawing to a different plot style at once? I want to change about 10 layouts from plot style A to plot style B, I have a couple drawings I have to do this to.
    Earth
    9,805
    Lightbulb Re: Batch Plot Style Change
    Quote Originally Posted by OCD View Post
    Give this a try. Replace "acad.ctb" with your desired CTB file.
    (vl-load-com)
    (vlax-for x
      (vla-get-Layouts
        (vla-get-ActiveDocument
          (vlax-get-acad-object)
      (vla-put-StyleSheet x "acad.ctb")
    R.K. McSwain | CAD Panacea |
    2007-08
    81
    Default Re: Batch Plot Style Change
    Thanks for the reply. I haven't dealt with this kind of code...so what extension will the file have and how do i load file to run?
    2007-08
    81
    Never mind figured it out. "lsp" and load as usual for lisp and it auto runs. Works great, thanks.
    2007-08
    81
    Is there a way to change the code to prompt for file? No big rush, code works great just trying to prevent from going back into lisp and changing each time.
    Earth
    9,805
    Exclamation Re: Batch Plot Style Change
    Ok, give this a try. This not only let's you choose a plot style, but it will determine if the drawing is set up for named plot styles or color dependent plot styles, and then present a list of the correct type from which to choose. The list is gathered from the current plot style path.
    (vl-load-com)
    (defun setplotstyle:mkdialog ( / fp)
      (setq fp (open (strcat (getenv "temp") "\\setplotstyle.dcl") "w"))
      (write-line "sps : dialog {" fp)
      (write-line "width = 30;" fp)
      (write-line "label = \"Select a plot style\";" fp)
      (write-line ": list_box {" fp)
      (write-line "key = \"lst\";" fp)
      (write-line "allow_accept = true;" fp)
      (write-line "height = 10;" fp)
      (write-line "is_enabled = true;" fp)
      (write-line "}" fp)
      (write-line "ok_cancel;" fp)
      (write-line "}" fp)
      (close fp)
    (defun C:SetPlotStyle ( / x pslist dcl_id ret *acad-object*)
      (setplotstyle:mkdialog)
      (if (zerop (getvar "PSTYLEMODE"))
        (setq filter "*.stb")
        (setq filter "*.ctb")
      (setq *acad-object* (vlax-get-acad-object))
      (setq pslist
        (vl-directory-files
        (vla-get-PrinterStyleSheetPath
          (vla-get-Files
            (vla-get-Preferences *acad-object*)
        filter
        1)
      (if pslist (setq pslist (acad_strlsort pslist)))
      (setq dcl_id (load_dialog (strcat (getenv "temp") "\\setplotstyle.dcl")))
       (cond ((not (new_dialog "sps" dcl_id))
              (princ "Unable to load DIALOG!")
              (exit))
       (action_tile "lst" "(setq ret (nth (atoi $value) pslist))")
       (if (not ret)(setq ret (itoa 0)))
       (action_tile "cancel" "(exit)")
       (start_list "lst")
       (mapcar 'add_list pslist)
       (end_list)
       (start_dialog)
       (unload_dialog dcl_id)
      (vlax-for x
        (vla-get-Layouts
            *acad-object*
        (vla-put-StyleSheet x ret)
      (vlax-release-object *acad-object*)
    ); end defun
    2013-04
    25
    That's cool.
    Is there any way to get it to recurse the directory to search the subdirectory of that folder?
    Thanks.
    2013-04
    25
    Found one. I just added the subdirectory path. And used a recursive fn from _gile. Link to post in code.
    ; UI to change all layouts to same PlotStyle
    (vl-load-com)
    	(write-line "width = 120;" fp)
    	(write-line "height = 70;" fp)
    	(write-line "}" fp)
    	(write-line "}" fp)
    	(close fp)
    ; Sud-dir routine by _gile
    ; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/vl-directory-files-for-subdirectories/m-p/7815896/highlight/true#M365740
    (defun allfiles	(folder pattern)
    	(apply 'append
    		(cons (if (vl-directory-files folder pattern)
    			(mapcar '(lambda (x) (strcat folder "\\" x))
    		(mapcar '(lambda (x) (allfiles (strcat folder "\\" x) pattern))
    			(vl-remove ".." (vl-remove "." (vl-directory-files folder nil -1)))
    (defun C:Plotstyle_Change_All_Layouts ( / x pslist dcl_id ret *acad-object*)
    	; (setq *acad-object* (vlax-get-acad-object))
    	; (setq pslist
    	; 	(vl-directory-files
    	; 		(vla-get-PrinterStyleSheetPath
    	; 			(vla-get-Files
    	; 				(vla-get-Preferences *acad-object*)
    	; 		filter
    	; 		1)
    	(setq pslist (allfiles "W:\\SS_CAD\\SS_AutoCAD Templates & Settings\\SS_Plotstyles" filter))
    		(exit))
    	(start_list "lst")
    	(end_list)
    	(start_dialog)
    	(vlax-for x
    		(vla-get-Layouts
    				*acad-object*
    ); end defun
  1. Specify the Plot Style for certain entities in a Named plot style drawing
    Last Post: 2014-10-28, 11:52 AM
  2. 2012: Can I change plot style with lisp or script?
    By dolan.raynor in forum AutoCAD General
    Last Post: 2013-07-18, 01:19 PM
  3. Change All Layers' Plot Style Setting
    By parker.depriest356295 in forum AutoLISP
    Last Post: 2013-02-05, 07:05 PM
  4. Named Plot Style OR Color Depemdent Plot Style
    By Masroor Javid in forum ACA General
    Last Post: 2007-09-11, 02:16 PM
  5. CHANGE PLOT STYLE TABLE
    By eng5 in forum AutoCAD General
    Last Post: 2005-03-08, 01:09 PM
