Thread: data extraction from attributes
    2007-09
    Macclesfield Cheshire, England.
    46
    Default data extraction from attributes
    Hi, I have several drawing files containing room area data in attributes. I can extract the room area data to an Excel spreadsheet, and I can also extract the room data to a table in AutoCAD which is updated if the attributes are edited (or if one is added), but I don't seem to be able to extract the room data to a spreadsheet in such a way that the spreadsheet gets updated if the attributes are edited (or if one is added). Can this be done?
    Maurice.
    2015-11
    Jo'burg SA
    4,512
    Default Re: data extraction from attributes
    Not directly. You have to run the DataExtract command again, overwriting the XLS file. Otherwise you can do something like this using some add-ons, there might be several available.
  1. Replies: 1
    Last Post: 2015-04-29, 01:18 PM
  2. Replies: 0
    Last Post: 2014-01-24, 07:48 PM
  3. Replies: 2
    Last Post: 2010-05-19, 02:51 PM
  4. dynamic block with attributes extraction to excel
    By parkerfeldman in forum AutoLISP
    Last Post: 2009-01-27, 09:14 PM
  5. Attributes Extraction
    By kpbh in forum VBA/COM Interop
    Last Post: 2004-07-22, 06:36 PM
