Thread: Educational plot stamps
    2004-06
    6
    Exclamation Educational plot stamps
    One of my friend complains that some drawings he received from a vendor while opened in AutoCAD 2004 gives a warning, "Educational plot stamp detected", and the same appears while plotting. Why this happens and is there any remedy for this?
    Thanks in advance,
    Abdul Huck
    email: acad.user@rediffmail.com
    2001-12
    St. Louis
    5,408
    Lightbulb Re: Educational plot stamps
    Quote Originally Posted by acad.user
    Thanks in advance,
    Abdul Huck
    AutoDesk Knowledge Base item:
    http://support.autodesk.com/getdoc.asp?id=TS63668
    Issue
    When you plot a drawing that was created in or that contains drawing data
    that was created in the Educational (Student and Faculty) version of
    AutoCAD® or AutoCAD-based software, the following plot stamp or watermark
    appears in the plot:
    For Educational Use Only
    Solution
    There is no way to circumvent the plot stamp. This is as designed to
    discourage the commercial use of an educational version of an AutoCAD
    product. Autodesk sells educational versions of software on the premise that
    the software will be used for educational purposes only.
    This can also occur when using blocks or other components of drawings that
    have been created or modified in an Educational version. This includes
    layers, blocks, layouts, and so on.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-05
    Austin, TX USA
    2,201
    Default Re: Educational plot stamps
    Check out the following thread
    Educational stamp issues
    2004-06
    6
    Smile Re: Educational plot stamps
    Thank you gentlemen for your information.
    Regards,
    Abdul Huck
  1. Educational Plot Stamp detected
    By cskelton in forum AutoCAD General
    Last Post: 2008-07-08, 07:38 AM
  2. Educational Plot Stamp
    By bart.lydon in forum AutoCAD General
    Last Post: 2008-07-02, 04:37 PM
  3. Autodesk Educational Plot Stamp, what is it.
    By sudhirkizhakoote in forum AutoCAD Plotting
    Last Post: 2005-10-12, 10:09 AM
  4. Plot Stamps
    By spencer.67965 in forum VBA/COM Interop
    Last Post: 2004-06-14, 08:35 PM
