Thread: better click-Drag Move & click-drag+Alt copy
    I could stop if I wanted to robmorfin's Avatar
    2003-10
    Solana Beach, CA
    200
    Default better click-Drag Move & click-drag+Alt copy
    when you click and drag and object you are moving this object, but oppossed to the move button, click-dragging doesn't pick any snap (should pick the closest snap where you are dragging it) and it doesn't lock the object path movement in any axis (shoul lock x & y axis and show the angles if click-dragging in an angle), well, at least this things happen when done with a circle, arc or group, not with the lines and walls, they do lock to the axis, but they don't show angles when moved in diagonal click-dragging, other object, I haven't checked.
    Click-drag+Alt copy behaves pretty much the same.
    I'm wishing for this because it's more handy and faster to do the click-drag but you loose the great advantage of Revit's intelligence to be always exact.
    2003-04
    Chino, CA
    4,756
    Default Re: better click-Drag Move & click-drag+Alt copy
    Very true, it would be nice to have some control with click-n-drag. Been playing with click-n-drag in AutoCAD 2005, and it functions the same way: no snaps, no ortho, etc.
  1. Replies: 0
    Last Post: 2011-11-16, 09:09 PM
  2. Drag move not working
    By June7 in forum AutoCAD General
    Last Post: 2009-06-09, 10:33 PM
  3. Right Click Menu: Copy/Move/Paste as block
    By akeener in forum AutoCAD Tips & Tricks
    Last Post: 2008-12-10, 03:25 AM
  4. Strange right-click drag problem
    By lambwill in forum AutoCAD General
    Last Post: 2007-10-04, 11:33 AM
  5. <Right Click>+Drag gives you a block
    By keelay711 in forum AutoCAD Tips & Tricks
    Last Post: 2007-04-23, 11:30 AM
