Originally Posted by
Greg Cashen
...I can do most of what I need with the stock components, tools and either in-place or external families. That said, it would be nice to be able to draw a typical foundation in 2D and 3D without using the floor or wall tool. I think it should be a separate tool, maybe like the hosted sweep tool, but smarter...I typically think of revit tools as building the virtual model in the same way that a contractor would build the building. I don't think this is currently acheived in Revit's wall or foundation tools. Think of a CMU wall with a pilaster in it. In real life, the pilaster is not a separate thing from the wall, but in revit it is...I now draw CMU pilaster as a 16" wall in between sections of a 8" wall. This way the surface patterns can align properly, etc.
I would like the foundation tools to allow me to bascially set the wall bottom level, including offsets, and then just "pick" it and draw a foundation along the bottom of the wall. it should know to go vertical at steps and if I need to put an integral spread footing in the foundation, it should be part of the same foundation...i.e., locked to the sweep or whatever it is and remain schedulable as a foundation.
Also, foundations should have a setting to appear in hidden line style in plans and elevations...without the workarounds...this is standard drafting practice.
...overall I am satisfied with the foundations. I WOULD like a retaining wall tool that was separate from the wall tool that allowed battered walls, toe width, heel width...As it is now, you draw a retaining wall as a wall and floor or as two walls...this is not intuitive and does not follow the real world of how it would get built.
