Results 1 to 10 of 12
Thread: Redefine Blocks
    2005-01
    58
    Default Redefine Blocks
    This may sound a bit of a simple question but...
    I have a block inserted in my drawing. I want reinsert that block as it has been amended. When I agree to redefine block, it will not update the block. When the new block is inserted it changes to the existing block. I want it the other way around. It has been driving me nuts for a little while now.
    2015-11
    Jo'burg SA
    4,512
    Default Re: Redefine Blocks
    Just a question ... is this block by any chance a dynamic block? I've had similar problems with redefining Dynamic Blocks. The work-around was (after redefining by insert / design center) to open the block in block editor, drawing a line, deleting it and close & save block editor. For some reason it then updates the existing block instances correctly.
    0,0,0 The Origin
    8,570
    and, if it's just a plain, old-fashioned block, it needs to be reinserted from outside the current file (select by browsing not by picking from the drop-down list).
    John B
    2005-06
    in the upper right corner
    3,268
    Quote Originally Posted by adampatten View Post
    Quick question...what is new about the amended block?
    If it's just attributes you're trying update, look into "attsync".
    Just a thought
    Ted
    ____________________________________________________________________ ________________
    Windows 10
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
    2004-08
    Hartford, Michigan
    3,197
    not to get off on a tangent, but does anyone have a lisp routine that can redefine a dynamic block that has had it's properties changed from default (i.e. *U5)? I figured I would ask before I tried to attempt to write one myself. I have some functions that allow me to change and update dynamic blocks, and select them in selection sets, but I dont believe it already has a built in subroutine that will redefine one.
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
    2015-11
    Jo'burg SA
    4,512
    I've also been thinking of such a routine - since this usually gives unexpected results. The way I think it should run is to step through each of those block instances, save it's Property values, reset the particular block to default, then re-apply the saved values.
    2004-08
    Hartford, Michigan
    3,197
    Quote Originally Posted by irneb View Post
    i dont believe that would work, even if you reset a db to its default properties, it doesnt return to its original name. I think you would have to redefine the insert command to allow it to replace all effective named blocks and then restore their original properties. the only problem with that is, what if the redefined block no longer has those properties?
    Windows 10
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by ccowgill View Post
    I beg to differ. Try this:
    1. Type (assoc 2 (entget (car (entsel)))) at the command prompt, pick one of your DB's which have non-default properties. After which the command prompt should show something like Select object: (2 . "*U72").
    2. Now type RESETBLOCK and select the same block.
    3. Repeat step one, it now shows the normal block name, not that annonymous name.
    You're definately correct on that score! It's the same problem as when attribute tag names have changed. Or removed / added to.
    2004-08
    Hartford, Michigan
    3,197
    i was unaware of the resetblock command, I was referring to manually changing the properties back to default. I will have to investigate this further and create a command. I can check a db's custom properties and if they are identical, use previous settings, otherwise display a message alerting the user to the changed properties
    Windows 10
    2004-07
    Detroit Michigan
    2,508
    Yeah, me either. I always deleted the block so I can reinsert the instance.
  1. Redefine Dynamic Blocks
    Last Post: 2015-11-17, 08:41 PM
  2. Redefine Blocks from Directory?
    By stusic in forum AutoLISP
    Last Post: 2012-10-24, 07:50 PM
  3. redefine blocks from another drawing
    By irneb in forum AutoCAD General
    Last Post: 2008-02-01, 07:09 AM
  4. Blocks will not redefine when inserted
    By bholden.97697 in forum AutoCAD General
    Last Post: 2005-10-28, 04:56 PM
  5. Using entmake to create (redefine) Blocks
    By melkor in forum AutoLISP
    Last Post: 2005-01-26, 11:51 PM
