Does Inventor have a continuous dimension tool similar to AutoCad? Where a string of dimensions can be created in a an aligned row with the next dimension referencing the last point dimensioned to or from.
I'm afraid not. You have to place the dims one at a time. Continuous dimensioning is usually bad in mechanical drawings (because of tolerance stack up), so it's not been a hot button issue.
Jonathan Landeros
KETIV Technologies
Orange County, California.
I've got a blog: www.inventor-tales.blogspot.com
“We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
Actually there is... There are several non-supported add-ins supplied with Inventor (think Express Tools...) They are part of a standard installation and can be found here:
"C:\Program Files\Autodesk\Inventor 2008\SDK\Tools\Users\DrawingTools"
They can be a bit tricky to get used to. Place the first dimension by selecting geometry (points/corners will highlight with an almost invisible green dot). Once the first dimension is created, keep selecting geometry to place the chain. Don't forget to right-click "Create"
Good luck...
