Results 1 to 6 of 6
Thread: 3D Polyline coordinates
    I could stop if I wanted to lmitsou's Avatar
    2003-01
    UK
    219
    Default 3D Polyline coordinates
    Hi all,
    I have a 3d survey and I am trying to get some coordinates from the 3d polylines. Is there any way (without having to do it manually which would take quite some time) to get x,y and z coordinates wherever there is a grip on a 3d polyline? Perhaps a routine that would automatically add x,y,z coordinates (text or mtext) to every grip of the 3d polyline. It would be a bonus if the text/mtext could be exported to csv, txt or xls format too.
    I have already used a lisp routine that did 2/3 of what I look for. I had to manually click on every grip point of the 3d polyline though which took ages.
    Thanks for your help in advance.
    2002-08
    43
    Smile Re: 3D Polyline coordinates
    Entsel to choose the object
    Entnext to move from one vertex to an other
    Entget to get dxf codes of a vertex
    Assoc 10 to retreive the x y and z coordinates
    Quote Originally Posted by lmitsou View Post
    Hi all,
    2007-08
    201
    Default Re: 3D Polyline coordinates
    Hi,
    You can have a look to this thread.
    2003-01
    UK
    219
    Quote Originally Posted by 'gile' View Post
    Hi,
    Hi gile (sorry I don't know your name),
    I tried to run your routine but it returns a BLANKTXT error. Not sure if I am doing something wrong. Can you please give me some instructions as to how it works?
    2007-08
    201
    Hi,
    You have to load the Poly-pts routine, then you paste the following expression on the command line
    ((lambda (/ ent)
       (if
         (and (setq ent (car (entsel)))
    	  (wcmatch (cdr (assoc 0 (entget ent))) "*POLYLINE")
          (Poly-Pts ent)
    2003-01
    UK
    219
    Hi gile,
    Thanks for the reply. It worked fine.
    Is there any way to have the coords appearing next to the vertices, perhaps as mtext or text or even blocks? This way they would be clearly visible on the drawing and also I could export them into excel.
  1. Select polyline and get coordinates
    By avinash patil in forum Dot Net API
    Last Post: 2012-11-04, 08:24 PM
  2. Polyline Coordinates finding
    By avinash patil in forum VBA/COM Interop
    Last Post: 2012-08-30, 11:29 AM
  3. Replies: 8
    Last Post: 2007-06-07, 07:53 PM
  4. Replies: 8
    Last Post: 2007-03-12, 11:30 AM
  5. Tracing polyline coordinates using map/lisp
    By bprabhakar001 in forum AutoLISP
    Last Post: 2006-06-21, 11:39 AM
