Results 1 to 7 of 7
Thread: Pasting taking to long
    2007-05
    Brisbane, Qld, Australia
    5
    Default Pasting taking to long
    Well I have recently started having a problem when I paste (Ctl+V) an item it to a drawing it takes a few minutes to come in. Has anyone had a similar problem? Is there any way to fix it?
    2008-07
    Ashtabula, OH
    4
    Default Re: Pasting taking to long
    Could you elaborate a little? Did this just start to happen, meaning you were able to do it before? What is the item? Are we pasting in 20 entities or 20,000? Does it contain nested blocks, or True Type font text? Or is it just lines and circles entities? I usually find True Type fonts will slow things down considerably. Pasting large quantities of objects can slow it down too.
    2007-05
    5
    The dwg is about 3mb. It has only started happening in the last 2 or 3 months. There are nested items in the dwging but I'm unable to get rid of them. As for the items that i'm copying and pasting, they aren't that big. I can copy, paste a BOM from inside the same dwg and it hangs for a few minutes. This also happens when I copy, paste anything from in this dwg. But I can copy, paste from some of our old Dwgs and no effect. Any ideas would be more than welcomed.
    2008-07
    Ashtabula, OH
    4
    The drawing size is pretty large. Have you tried to Purge the drawing, then perform an Audit. Both commands should be under File>Drawing Utilities. I've had Audit find and fix 7000+ errors on a rather small and simple drawing (file <500kb). You may be pasting problems from one drawing right into another. Or may have pasted a problem into the drawing you're talking about. Purging and auditing each drawing is a good habit to get into. Keeps file sizes down and it doesn't take long. A few seconds to do both. Certainly couldn't hurt to try.
    2007-05
    5
    Thanks cad guru. But these where about the first 2 things I thought of but still didn't help. Man this is really starting to get to me. My manaegr thinks it could be the computer letting us down so he has ordered me a new system with a Quad core 2.66 and 4gig of ram. My current system is about 4 years old and runs a single 3.4 with 1.5 gig of ram. I hope this helps to fix the problem! If not I'm getting a new system for nothing LOL
    2001-07
    319
    You could use the longer path by making a wblock of what you want to paste.
    2007-05
    5
    Thanks for the responses. In the end I finally talked the boss it to putting 2009 on my machine and now the problem is gone. It had something to do with having to may annotated scales in the dwg. 2009 reconized this and fixed it.
  1. Synchronizing with Central all of a sudden taking a VERY long time
    By jameswest77 in forum Revit - Hardware & Operating Systems
    Last Post: 2011-02-04, 06:12 AM
  2. Macro taking a long time to run
    By drodrigues in forum Revit - API
    Last Post: 2009-06-15, 09:01 PM
  3. Drawings taking to long to send to 1050C plus plotter
    By kimlance in forum AutoCAD General
    Last Post: 2009-03-20, 10:42 AM
  4. Replies: 0
    Last Post: 2008-05-15, 01:04 PM
  5. Exporting 3d to Autocad, taking too long
    By sifuentes in forum Revit Architecture - General
    Last Post: 2005-03-10, 05:41 AM
