I'm fairly new to Revit, so I might be doing something way wrong. I'm trying to create rafters on a hip roof using a reference plane at the bottom of the roof sheathing. When I go to sketch the beam system, the pick supports tool is correct when i pick the supports parallel to the rafters, but when I pick the supports that will actually support the rafters, the line created is not aligned with the support. I cannot get the line to align to the center of the support even if i use the align tool. I suppose this is due to the sloped reference plane. Is the line displayed correct, or is there an issue with picking supports when using sloped reference planes?
