Thread: Page Setup Overrides not changing when switching projects
    2008-01
    67
    Default Page Setup Overrides not changing when switching projects
    Hi,
    I apologize if this has been asked previously.
    Using AMEP 2008:
    When switching projects, the page setup overrides do not change. They stay as the ones associated with the previously open project.
    The workaround is to shut down ACAD MEP 2008 and reload.
    Any ideas? Bug maybe?
    Thank you,
    paul_mep
    2008-01
    67
    Default Re: Page Setup Overrides not changing when switching projects
    As a follow-up, the (better) work-around is to right click and select properties on the sheet set from within Navigator - then just click OK and it will refresh the overrides.. hopefully this helps someone out.
  1. 2011: Can't publish using page setup overrides
    By Craig_L in forum AutoCAD General
    Last Post: 2011-02-08, 01:55 PM
  2. Limited Page Setup Overrides?
    By modulor in forum AutoCAD Sheet Set Manager
    Last Post: 2010-01-12, 03:44 AM
  3. Page Setup overrides organization via Sheet Set Manager
    By caduzer in forum AutoCAD Sheet Set Manager
    Last Post: 2007-08-03, 11:12 PM
  4. Page Setup Overrides
    By martyk in forum AutoCAD General
    Last Post: 2005-06-03, 09:11 PM
  5. Page Setup Overrides in SSM
    By bskripac in forum AutoCAD Wish List
    Last Post: 2005-02-02, 02:09 PM
