Thread: Formula Property Definition : "Sample Result"
    2008-07
    2
    Exclamation Formula Property Definition : "Sample Result"
    I have a trouble with the edition of my vbscript formula ... When I typed my formula, it didn't assess it in the frame 'Sample result'. Have you a solution to propose to me?
    I already try to reinstall vbscript but there is nothing. It seems to miss an option in MEP but i don't know this one.
    Thanks for your help
    Julien
    2003-10
    San Francisco CA
    1,190
    Default Re: Formula Property Definition : "Sample Result"
    Quote Originally Posted by julien.hofman View Post
    Julien
    Hi Julien,
    A couple of observations about your formula that may help.
    The first thing I would do is to try using a different variable such as "PType". I think the variable "type" may be the problem.
    Second you may want to add an Else statement in case "Elbow" or "Transition" are not the [PartType]
    Finally you might think of changing your formula to a Select Case formula instead of the If/Then that way if you want to add other part types in the future it will be just a matter of adding more cases.
    Hope this help,
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2008-07
    2
    Thanks for your quick answer.
    Effectively, it's a syntax error! I thought it was something else!
    I have wrote my formula of an other way and it works!
    Julien
  1. Formula Property Definition PLEASE HELP
    By douglas.167342 in forum ACA General
    Last Post: 2010-02-18, 10:34 AM
  2. formula function in property set definition
    By sam_ctlim in forum AMEP General
    Last Post: 2009-03-05, 11:07 PM
  3. Formula Property Definition
    By jgardner.79905 in forum VBA/COM Interop
    Last Post: 2006-06-13, 12:58 PM
  4. Problem with Formula Property Definition
    By mflure.80520 in forum Style Management
    Last Post: 2005-08-18, 10:39 PM
  5. Formula Property Definition
    By arcadia_x27 in forum ACA General
    Last Post: 2004-09-10, 06:26 PM
