Not sure if this is the correct forum for this. We use the Carlson SurveCe data collector software which stores the survey as an RW5 file. I need to convert this RW5 to a FBK to import into AutoCAD in order to obtain the linework. I previously used the Carlson Connect Add-On which worked fine to convert between the two the problem being that I don't see a 2009 version and Carlson always seems to be half a cycle behind AutoCAD for updates. Is there an external or standalone program that can do this seemingly easy transformation for me? I tried to use the survey data collection link but it just sits there without completing the conversion for all the options I tried. Any suggestions, workaroundsor comments?
Thanks
