Thread: part builder
    2008-04
    41
    Question part builder
    Civil 3d-09:
    Under pipes --> then part builder, I click on any structure ----> then modify part sizes.
    From here it opens up the working block with whatever part I selected to modify. My problem is the properties box with all the parameters that usually opens with the block is not showing up. Any command I can type in to make this appear. Thanks for your help and suggestions.
    ~Bill
    2005-04
    Richmond, VA
    73
    Default Re: part builder
    At first blush it seems like the properties palette is coming up in a ficticious area of your screen.
    Lynn Allen has a post that may help:
    http://lynn.blogs.com/lynn_allens_bl...ocad_hip_.html
    Another trick is to change your screen resolution to force AutoCAD to reposition things.
    Hope that helps.
    Donnie
  1. CV218-4: Get the Part: AutoCAD Civil 3D Part Builder
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:52 AM
  2. 2012: Part Builder
    By valejandro_ibarra in forum AutoCAD Civil 3D - Pipes
    Last Post: 2013-03-22, 08:24 PM
  3. 2011: Part Builder/Catalog
    By Michael Anderson in forum AutoCAD Civil 3D - Pipes
    Last Post: 2011-09-15, 12:09 PM
  4. Part Builder Parameters
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2010-11-20, 01:01 PM
  5. Part Builder
    By a.navarrete in forum Español - AutoCAD Civil 3D
    Last Post: 2009-04-16, 02:33 PM
