Results 1 to 9 of 9
Thread: Elevation at bottom
    2006-02
    29
    Default Elevation at bottom
    Hi!
    We have a situation where we have tagged some isolated footings with the tag that shows elevation at bottom, and have then relocated the project up in z value by 200mm. The thing is that the elevation at bottom does not update, and now shows a value that is 200mm too low, in other words totally wrong. It seems that the tag is correct, as long as it only shows the elevation at bottom information from the properties of the footing. The footing family is not updating that value when you relocate. Anybody understanding what I mean, and has anybody else experienced this?
    Best regards
    Henning, Norway
    2002-02
    St. Louis, MO
    4,695
    Default Re: Elevation at bottom
    The value can report either the shared or project coordinate. You will need to switch this in the tag family settings.
    The same applys to other elements such as level lines.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    2006-02
    29
    Ok, but how do I do that?
    Thanx
    2002-02
    St. Louis, MO
    4,695
    Which object did you use for the tagging? A spot elevation? If so, select it > open the properties > Edit/New > Change the Elevation Origin property to the desired type.
    Aaron Rumple, AIA
    2006-02
    29
    The problem is when I tag an isolated foundation with the tag: Structural foundation tag with elevation. The tag gets the elevation from the dimension parameter elevation at bottom on the footing, and the problem is that this value does not update when I elevate the building in z direction.
    2007-10
    Quote Originally Posted by aaronrumple View Post
    Does this really work for structural foundation tags? I've been trying to get a foundation tag to report the shared elevation for the "Elevation at Bottom" parameter, but I'm having trouble finding out if I can do that. I'm thinking since this a system parameter, I can't edit it.
    I've attached a copy of the tag I'm using if anyone wants to take a look.
    Thanks!
    2008-04
    270
    Quote Originally Posted by roland.106412 View Post
    This isn't a tag I have used, but looking at it now, it seems the parameter 'Elevation at Bottom' gives you a bearing level for the foundation based on the level that foundation is associated with.
    So if the foundation is at Level 0, and it is 450 deep the bottom elevation will read -450. If the foundation is at Level 99.100 and the foundation is 450 deep, the tag will still read -450.
    See attached images.
    I don't think this parameter actually reades the 'true elevation'
    2007-01
    226
    I use spot elevation to tag elevations, this works good for me.
    with wall and isolated footings and other objects.
    I tried to make a tag family the same as you, without much luck.
    I am sure there is a way, since the spot elevation does the job, but this is a system family
    it is pulling hidden properties from the object to deal with elevations.
    maybe someone at the factory could give us some a few tips on how to extract this info for objects..?
    With spot elevation set elevation origin to shared, and if the shared elevation changes then
    all elevation will update correct.
    2007-01
    Glenside, PA
    71
    I've had rediciulous problems with Footing tags with elevations. Especially with shared coordinates and wall footings. All the responses I got back from Autodesk is that its a known problem and no hope in sight for a fix. Our final solution was the same as previous poster 'dmahan', we use spot elevations for bottom of footing. Just make sure the elevation is reading bottom and you're good to go.
  1. 2013: Elevation Editor Jumps to Bottom of List after Editing Elevation Value
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2014-03-21, 07:01 PM
  2. Add bottom of elevation to beam tag?
    By zanno in forum Revit Structure - General
    Last Post: 2011-05-06, 07:00 PM
  3. Elevation at Bottom
    By cbaze in forum Revit Architecture - General
    Last Post: 2009-10-05, 06:48 PM
  4. Foundation. Elevation of Bottom value
    By E-Key in forum Revit Structure - General
    Last Post: 2008-05-01, 06:32 PM
  5. Bug: Bottom of Footing Elevation
    By Steve Mintz in forum Revit Structure - General
    Last Post: 2006-05-25, 07:36 PM
