Results 1 to 10 of 10
Thread: Proper setup of Object Enablers
    2000-01
    Seattle WA USA
    5,859
    Lightbulb Proper setup of Object Enablers
    I see many questions related to getting object enablers working properly in NavisWorks 2009.
    Here is the correct procedure for supporting AutoCAD MEP 2008. The steps will be similar for other AutoCAD products.
    Install the Object Enablers
    Object Enablers for NavisWorks
    Note that the ACA OE is required to support the AMEP OE!
    1. Install the AutoCAD Architecture 2008 OE (must be installed first)
    2. Install the AutoCAD MEP 2008 OE
    Set the loaders for DWG in Tools, Global Options
    1. Start NavisWorks and go to Tools, Global Options, File Readers, DWG/DXF/SAT
    2. Set DWG Loader version to 2008 (If you are supporting other versions, set appropriately.)
    3. Close Navisworks
    Clear existing cache files
    Cache files will reload the bad representations unless the drawing is more recent than the cache file.
    1. Delete any existing .nwc files
    This information is finally documented by Autodesk, but apparently is only available to Subscription customers. I've included this link for Subscription customers.
    R. Robert Bell
    Design Technology Manager
    Stantec
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Default Re: Proper setup of Object Enablers
    Great post Robert.
    Here are some other object enablers I have found:
    CAD-Duct
    ShipConstructor
    MagiCAD
    AutoPlant
    That's all I have for now...
    2006-05
    Riverside, California
    140
    For the newer folks that don't know how to see what O.E.'s they are missing.....
    Cick the pull down menu >View >[Scene Statistics]
    The resulting window will list any missing O.E.'a and the quantity of objects that were not rendered. Also listed is the company that should have to O.E. available (note that sometimes Autodesk is listed when another company is acutally responsible).
    Verify with the person supplying the cad file what it was rendered with, and ask if they have the correct enabler available for you (quicker and easier, plus it is usually correct), or have a direct link to the download page.
    Download the enabler and execute it to install.
    You may have to restart Navis.
    I have recently worked with the Autodesk Product Support to clear a long standing O.E. issue, and the order of installation really does matter. I had to install every O.E. that we could find to finally clear my issue, and some won't install until others are installed first.
    There doesn't seem to be any documentation on this order of installation, nor could we explain why I had the one recurring issue which doesn't seem to be an issue for most users.
    Perk
    Last edited by RobertB; 2008-08-18 at 03:24 PM. Reason: Corrected menu item spelling
    2000-01
    Seattle WA USA
    5,859
    Autodesk has finally released an official TS document regarding obejct enablers for NavisWorks.
    R. Robert Bell
    Stantec
    2016-01
    Quote Originally Posted by RobertB View Post
    Autodesk has finally released an regarding obejct enablers for NavisWorks.
    Were might one find OE for 2009 MEP 64bit?
    2004-07
    Fort Collins, CO
    1,329
    2016-01
    Thanks David
    I still have an issue attempting to view MEP objects in Navis Manage 2009 on a 64 bit system. Have you experienced this or perhaps found a work around?
    The only way I have been able to view MEP objects thus far is to export a NWC in AutoCAD and then view in Manage. Not the best solution on a large project with multiple players.
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by deisman View Post
    You must install the ACA object enabler before the MEP object enabler.
    R. Robert Bell
    Stantec
    2008-07
    5
    I followed the installation of the OE EXACTLY as stated in hte below post. I still cant get MEP 2009 elbows or Y's to import into Navisworks as a solid it is only in wireframe. I even had the contractor run and AECCONVERTTOMASSELEMENT command first. Anyone have any ideas.
    2008-10
    40
    This is more for autocad, but I will post here anyway. To avoid database data bloating of dwgs containing proxy objects (increased file sizes when using object enablers in autocad), set the autocad default save to 2004 or later. this bloating bug seems to have been fixed in the 2004 format.
  1. Object Enablers..
    By Dr._House in forum AMEP General
    Last Post: 2012-10-17, 05:01 PM
  2. Object Enablers
    By art.theusch in forum NavisWorks - General
    Last Post: 2010-05-19, 03:47 AM
  3. Object Enablers
    By Steve Cook in forum NavisWorks - General
    Last Post: 2009-07-29, 01:26 PM
  4. Object Enablers
    By bjlottis in forum DWG TrueView - Wish List
    Last Post: 2007-12-21, 05:55 PM
  5. Beyond Object Enablers ....
    By rclayton in forum CAD Management - General
    Last Post: 2005-06-02, 03:56 PM
