Thread: macro:
    2004-08
    Beaverton, Or.
    131
    Default macro:
    I have a VBA macro loaded automatically with every drawing opened or new drawing created.
    (COMMAND "-VBARUN" "timelog.dvb!Module1.login")
    It works fine as long as you are opening one drawing at a time, but if I try opening multiple drawings autocad hangs with "MACRO:" at the command prompt. The only way I can get cad to continue is to use a cancel button I have programed into the menu.(the keyboard is unresponsive)
    2007-12
    68
    Default Re: macro:
    try something like this:
    (vl-vbaload "c:/timelog.dvb")
    (VL-VBARUN "Module1.login")
    2000-01
    Seattle WA USA
    5,859
    Default Re: macro:
    Make sure your macros are executed from with the S::Startup Visual LISP routine.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2002-02
    Kansas
    487
    Default Re: macro:
    Try puting your macro in the ACAD.dvb this will auto load with autocad start
    then run you macro by calling it from the Appilcation.EndOpen Event of Autocad
    This way ever Drawing open will call the macro after it is open up.
    or you can make your macro the code for the Appilcation.EndOpen Event of Autocad
    Note:
    update to 2011
    I am using ADT 2007 08/06/2008
    PS. If you use any Code I post or Down Load Attachment I would like to know if it was helpful. So please post reply to this thread, on how you use the code or down load. Thank You
  1. CP222-2: Autodesk Revit VSTA: Writing Your First Macro An Introduction to the Macro Manager
    Last Post: 2014-12-01, 02:12 AM
  2. Run Macro
    By rafael.freitas in forum VBA/COM Interop
    Last Post: 2010-05-25, 02:58 PM
  3. 2011: Macro's
    By JLHConsulting in forum AutoCAD General
    Last Post: 2010-04-27, 06:02 PM
  4. Challenging Macro to reverse the function of an existing macro
    By parminderkeilah in forum VBA/COM Interop
    Last Post: 2008-05-19, 02:50 PM
  5. call script within macro & nested macro
    By wahyudin in forum AutoCAD LT - General
    Last Post: 2007-10-22, 01:10 PM
