How can I create an X inside a rectangle by picking only 2 points?
thanks in advance.
thanks in advance.
Store the two selected points in variables, then use the X/Y coordinates from each point combined to make the alternate, unpicked, points.
R. Robert Bell
Design Technology Manager
Stantec
i am a beginner lisp user...can you please explain how to get the x,y coordinates without actually listing them as my 2 pick points...
this is all i have so far. pt3 and pt4 i still don't know how to get.
(defun c:LX (/ pt1 pt2 pt3 pt4)
(INITGET 1)
(SETQ pt1 (GETPOINT "\nPICK 1st POINT OF LINE: "))
(SETQ pt2 (GETPOINT "\nPICK 2nd POINT OF LINE: "))
(SETQ pt3 ()
(SETQ pt4 ()
(command ".layer" "m" "G-FINE-XTRA" "C" "1" "" "")
(vl-cmdf ".LINE" pt1 pt2 "")
(vl-cmdf ".LINE" pt3 pt4 "")
you may also want put this line inCode:(setq pt3 (list (car pt1)(cadr pt2))) (setq pt4 (list (car pt2)(cadr pt1)))
Code:(SETQ pt2 (getcorner "\nPICK 2nd POINT OF LINE: " pt1))
In addition to lpseifert's comments, may I offer a few other suggestions since you are just starting out?
- Stick with lower case letters for all the pre-defined functions. Your code is difficult to read given the mixed use of full caps vs. lower caps.
- Attempt to emulate the prompting of OOTB commands. Don't use all uppercaps at the command prompt.
- Use the underscore for OOTB commands and options, to allow international folks to try your code in their languages.
- Be consistent in using (initget) where desired. You are leaving the user open to cancelling the routine at the 2nd prompt, but not trapping the exit.
- Use (and) to verify inputs before executing commands that need the input (see sample code).
- Use longer command function names for the main code, and provide a 2nd command function for the keyboard shortcut. This gives your users the ability to make their own shortcuts of your command functions.
- Leave the user's environment as you found it. You set the current layer, but don't restore the original one.
- Users like running OSnaps. If you use the command function to draw objects, make sure you use the None OSnap override.
- Trap common errors that can occur, such as your desired layer being frozen.
- Never use hard-coded data more than once. For instance, the layer name is bound to a variable to reduce typing errors and provide a single location to change the layer's name.
Code:;;; Main command function (defun C:DrawBoxX (/ pt1 pt2 pt3 pt4 cLayer layerName) (cond ((and (setq pt1 (getpoint "\nSpecify first corner point: ")) (setq pt2 (getcorner "\nSpecify other corner point: " pt1))) (setq pt3 (list (car pt1) (cadr pt2))) (setq pt4 (list (car pt2) (cadr pt1))) (setq cLayer (getvar "CLayer")) (setq layerName "G-Fine-Xtra") (cond ((not (tblsearch "Layer" layerName)) (command "._Layer" "_m" layerName)) ((command "._Layer" "_t" layerName "_on" layerName "_s" layerName))) (command "_c" "1" layerName "") (vl-cmdf "._Line" "_non" pt1 "_non" pt2 "") (vl-cmdf "._Line" "_non" pt3 "_non" pt4 "") (setvar "CLayer" cLayer))) (princ)) ;;; Below is a shortcut command function (defun C:LX () (C:DrawBoxX))
R. Robert Bell
Stantec
